Optimizing Outdoor Lighting with Govee
I recently upgraded my outdoor lighting setup with the Govee H705B bulbs and have been thoroughly impressed with their performance. However, I encountered an issue where the color settings I programmed for my lights would revert to white after a few days. After some research and reaching out to the community, I found a reliable solution that ensures my lights stay green all night long until I decide to change them again. Here’s how I did it:
  1. Firmware Update: First, I ensured that my Govee bulbs were running the latest firmware. This step is crucial as newer versions often include bug fixes and improved functionality.
  2. App Settings: Within the Govee app, I discovered a setting that locks the color mode. By enabling this, the bulbs no longer revert to their default white setting. This feature is perfect for maintaining consistent outdoor lighting without constant adjustments.
  3. Automation Setup: I also set up a simple automation using my smart hub to periodically check the bulb settings. This serves as a backup measure, ensuring that even if the bulbs were to reset, they would quickly revert to my desired green color.
  4. Community Support: I couldn’t have figured this out without the helpful tips from this forum. It’s amazing how a community can come together to solve problems and share knowledge.
If you’re struggling with similar issues, I highly recommend checking out the latest firmware updates and exploring the app’s hidden settings. Sometimes, the solution is just a few taps away! Thanks to everyone who contributed to the discussions that helped me out. :star2:
