Optimizing Raspberry Pi Performance for OpenHAB and InfluxDB
Hi everyone,
I wanted to share my experience and findings after upgrading my Raspberry Pi 3B setup. I recently migrated from Raspbian Lite 32-bit to Raspbian Lite 64-bit and noticed some performance issues, particularly with openHAB 3 and InfluxDB 2. I thought it might be a good opportunity to explore and share my journey in optimizing the system.
The Setup
  • Raspberry Pi 3B
  • Raspbian Lite 64-bit
  • Dockerized openHAB 3
  • Dockerized InfluxDB 2
The Issue
After the upgrade, I noticed that the system was struggling with high swap usage, often hitting 100%. Even when running openHAB 3 alone, without InfluxDB 2, the swap usage remained excessively high. This was concerning as it made the system unresponsive at times.
Initial Investigations
  1. Swap Usage Analysis: I checked the swap usage extensively. Both openHAB 3 and InfluxDB 2 seemed to contribute to the high swap usage, but even with InfluxDB stopped, openHAB alone was enough to cause the issue.
  2. System Monitoring: I monitored the system using tools like htop and free -h to understand memory and swap usage patterns.
  3. Testing Different Configurations: I tried running different versions of openHAB (both stable and milestone releases) to see if the issue was consistent across versions.
Findings
  • Raspbian 64-bit Compatibility: It appears that Raspbian 64-bit might not be the best fit for the Raspberry Pi 3B, especially when running resource-intensive applications like openHAB and InfluxDB.
  • Memory and Swap Configuration: The default swap settings on Raspbian 64-bit seemed inadequate for the workload. Adjusting the swap size and configuration helped alleviate some of the pressure.
  • Docker Resource Limits: Limiting the resources allocated to Docker containers for openHAB and InfluxDB proved to be beneficial. This prevented a single container from monopolizing system resources.
Solutions and Workarounds
  1. Increase Swap Space: I increased the swap size to 2GB, which provided more breathing room for the system.
  2. Optimize Docker Settings: I configured Docker to limit CPU and memory usage for both openHAB and InfluxDB containers. This ensured that neither application would hog all available resources.
  3. Switch to Raspbian 32-bit: As a last resort, I considered reverting to Raspbian 32-bit. While this wasn’t ideal, it significantly reduced swap usage and improved system responsiveness.
Lessons Learned
  • Hardware Limitations: The Raspberry Pi 3B, while capable, has its limits. Running multiple resource-intensive applications simultaneously can push it to its limits.
  • Configuration is Key: Proper configuration of swap, Docker, and system resources is crucial for maintaining performance.
  • Community Support: The openHAB and Raspberry Pi communities are incredibly helpful. Reaching out for advice and sharing experiences can lead to valuable insights.
Looking Ahead
I’m now considering whether to stick with Raspbian 32-bit for stability or explore alternative solutions like upgrading to a Raspberry Pi 4B or using a different OS altogether. If anyone has experience with similar setups or optimizations, I’d love to hear your thoughts!
Happy tinkering! :blush:
