Hey everyone, I wanted to share my recent experience optimizing the connection between my Alexa Echo Dot and Amazon Firestick TV. I’ve been using this setup to display my Wyze cameras on the TV, but I was dealing with some frustrating buffering and long connection times. After doing some research and experimenting, I found a solution that made a huge difference!
First, I adjusted the bandwidth settings on my Asus router to 2.4 GHz, which helped stabilize the connection. Then, I played around with the channel settings—Asus suggested using channels 1, 6, or 11. Channel 1 worked best for me, reducing interference significantly. I also disabled Explicit Beamforming and Universal Beamforming under the professional settings, which further improved the connection speed.
The biggest breakthrough was adjusting the Hertz setting from 20Hz to 40Hz. This tweak really smoothed out the buffering issues, and now I can access my camera feeds in under 10 seconds instead of the previous 30+ seconds. I also made sure the security level was set to WPA2-Personal, which seemed to lock everything in place.
I’d love to hear if others have tried similar optimizations or have additional tips! It’s amazing how a few small adjustments can make such a big difference in smart home setups. ![]()
