Optimizing Smart Lighting Automation: My Journey and Tips
Recently, I’ve been diving into creating a seamless smart lighting system in my kitchen, and I wanted to share my experiences and tips with the community. The goal was to have the lights automatically adjust based on TV usage and manual controls, but I quickly realized my initial setup was a bit clunky.
My Setup
I have three LED strips controlled by dimmers: k_hood_ltv, k_hood_lmain, and k_hood_lplita. One of these strips is positioned above the TV (NH_LG), and I wanted it to turn off when the TV is on and vice versa. The lights are triggered by a button (K_hood_bl), and I’ve set up several rules to manage this.
Challenges and Solutions
Initially, I created separate rules for turning the lights on and off, but I felt the logic was too cumbersome. After some research and experimentation, I streamlined the rules to make them more efficient. Here’s what I learned:
  1. Combine Conditions: Instead of having separate rules for every possible state change, I combined conditions within a single rule. This reduced redundancy and made the system easier to maintain.
  2. Use Variables for Simplicity: I started using variables to store states, which made the rules cleaner and more scalable. For example, I now use a variable to track whether the TV is on or off, which simplifies the logic significantly.
  3. Test Incrementally: I tested each part of the system incrementally. Starting with the TV light interaction, then moving on to the manual controls. This helped me identify issues early on and fix them without overwhelming myself.
Streamlined Rules
Here’s the simplified version of my rules:
plaintext
rule “Kitchen Lighting Automation”
when
Item K_hood_bl changed or
Item NH_LG changed
then
if (NH_LG.state == ON) {
k_hood_lplita.sendCommand(100)
k_hood_lmain.sendCommand(100)
} else {
k_hood_ltv.sendCommand(100)
if (K_hood_bl.state == OFF) {
    k_hood_ltv.sendCommand(0)
    k_hood_lmain.sendCommand(0)
    k_hood_lplita.sendCommand(0)
end
This single rule now handles all the necessary interactions, making the system more efficient and easier to troubleshoot.
Tips for Others
If you’re working on a similar project, here are some tips:
  • Start Small: Begin with a basic setup and gradually add complexity. This helps you understand how each component interacts.
  • Document Everything: Keep a detailed log of your rules and changes. This will save you time in the long run, especially when troubleshooting.
  • Leverage Community Resources: Don’t hesitate to look for similar setups in forums or documentation. Often, others have faced the same challenges and can offer valuable insights.
Conclusion
Optimizing my smart lighting system was a rewarding experience. It taught me the importance of simplicity and thorough testing. If anyone has questions or needs help refining their rules, feel free to reach out! I’d be happy to share more details or troubleshoot together.
Happy automating! :rocket:
