As I delve deeper into the world of smart home automation, one of the most fascinating areas I’ve explored is the integration of circadian lighting systems. The ability to adjust color temperatures throughout the day to mimic natural light has been transformative for my living space. I’ve been experimenting with creating a rule in my smart home platform to automate this process, and I’d love to share my journey and insights with the community.
Initially, I came across two approaches: one using a built-in feature in my hub and another relying on an external app. However, both had their drawbacks. The hub-based solution seemed outdated, and the app-based one had issues with keeping lights on unnecessarily. This led me to think about a more customized solution. I envisioned a system where each light bulb could reference a global variable for color temperature, which would update dynamically based on the time of day.
The challenge I faced was calculating the exact percentage of time elapsed between sunrise and solar noon, which would determine the color temperature adjustment. For instance, if sunrise is at 5:20 AM and solar noon at 1:18 PM, the time between them is roughly 7.96 hours. At 10:40 AM, which is about 66% of the way through this period, the color temperature should transition from 2200K (softer, warmer light) to 5000K (cooler, daylight). This calculation would need to happen every 15 minutes to ensure smooth transitions.
I explored using global variables in my system and even looked into scripting options, but the math involved in calculating the time progression was a bit daunting. I stumbled upon some community discussions where others had used fade effects for smooth transitions, which inspired me to consider a hub-based solution without relying solely on external apps.
After some trial and error, I managed to create a system that updates the color temperature every 15 minutes based on the calculated percentage of the day that has passed. This not only mimics natural light but also enhances comfort and productivity throughout the day. The integration with my existing smart home ecosystem has been seamless, and the results have been nothing short of impressive.
I’d love to hear from others who have tackled similar projects or have suggestions for improvement. Whether you’re looking to implement circadian lighting or enhance your current setup, sharing experiences and tips can only make our smart homes better. Let’s continue to explore and innovate together!
Cheers,
