Optimizing Smart Lighting with Input Select Automation
I’ve been diving into Home Assistant’s automation capabilities lately, and I’m thrilled to share my experience with the community! One feature that has really impressed me is the ability to use input_select entities to trigger scripts, allowing for a high degree of customization and control over smart lighting setups.
My goal was to create a seamless way to switch between different lighting modes in various rooms, such as daylight, warm, relax, and night settings. I found that using input_select combined with scripts was the perfect solution. However, I ran into a bit of a hurdle when trying to dynamically call the correct script based on the selected option.
Initially, my automation wasn’t working as expected because I wasn’t correctly referencing the state of the input_select entity. After some research and experimentation, I realized that using data_template with the states function was the key to dynamically invoking the right script. Here’s the corrected version of my automation setup:
yaml
alias: ‘Cycle Living Light’
initial_state: true
trigger:
  • platform: state
    entity_id: input_select.cycle_living_lights
    action:
  • service: script.turn_on
    data_template:
    entity_id: >-
    {{ states(‘input_select.cycle_living_lights’) }}
This setup now works flawlessly! It allows me to switch between predefined lighting scripts based on my selections, making it incredibly easy to adjust the ambiance of my living space with just a few clicks. I’m excited to explore even more possibilities with Home Assistant’s automation features and look forward to sharing my journey with you all!
If anyone has tips or alternative approaches for similar setups, I’d love to hear them! Let’s continue to learn and grow together in the amazing world of smart home automation. :star2:
