Optimizing Solar Energy with Home Assistant
Hey everyone, I’m really excited to share my journey with Home Assistant and my Anker SOLIX solar system. :sun_with_face: I’ve been working on optimizing my solar energy setup, and it’s been quite the adventure!
My Setup:
I have an Anker SOLIX Solarbank E1600 (Gen 1) paired with a Solarbank 2 E1600 Pro and a smart meter. My solar panels generate up to 2000W, and my goal is to maximize the energy I feed back into the grid while ensuring my home’s needs are met.
The Challenge:
Currently, my system starts feeding excess energy into the grid around 1 PM when the battery is full. This means a lot of potential energy is unused during the day. I want to start feeding energy earlier, around 10 AM, when solar production is high, and use the battery for times when production drops below home consumption.
What I’ve Tried:
I’ve explored using Home Assistant to automate this process. It seems like the Anker SOLIX integration allows for some customization, but I’m not entirely sure how to adjust the settings to achieve my goal. I’ve also considered whether an external energy management system might be necessary, but I’m hoping to keep things simple with what I have.
Questions for the Community:
  1. Has anyone successfully adjusted their Anker SOLIX system to start feeding energy earlier?
  2. Are there specific parameters or settings within Home Assistant that can control the bypass mode timing?
  3. Are there any potential risks or considerations I should be aware of when altering the system’s default behavior?
Why This Matters to Me:
Maximizing my solar energy contribution not only helps the environment but also makes my investment in renewable energy more impactful. Every watt counts, and I’m eager to squeeze the most out of my system!
Looking Forward:
I’m really hopeful that the community can shed some light on this. Whether it’s through Home Assistant automation or adjusting the Anker settings, I’m ready to dive in and make this optimization happen. Let’s make solar energy work smarter for us! :rocket:
Thanks in advance for your insights and suggestions!
Best regards,
Swaehn
