Optimizing UPS and Smart Lighting Setup for Home Automation
Hey everyone, I’m diving into optimizing my home automation setup and wanted to share some experiences and questions I’ve encountered along the way. Hopefully, this can spark some helpful discussions!
1. Optimizing UPS Power Management
I’ve been researching how to calculate the optimal UPS capacity for my setup to ensure maximum efficiency and reliability. From what I understand, it’s crucial to balance the UPS’s power output with the devices’ power consumption to avoid overloading or underutilizing the UPS. I came across some helpful resources, but I’m still curious if there’s a more streamlined method or tool that can assist in this calculation. If anyone has tips or tools they swear by, I’d love to hear about them!
2. Zigbee Button Integration with MQTT
I recently set up a Sonoff ZigBee Bridge flashed with Tasmota and integrated it with MQTT. While most devices work seamlessly, I’m encountering some quirks with a motion sensor. The MQTT messages are being received, but the automation isn’t triggering as expected. I suspect the issue lies in how the MQTT discovery message is structured. Here’s a snippet of what I’m working with:
python
homeassistant/device_automation/0x2FFA/0x2FFA/config
“name”: “Doorbell”,
“automation_type”: “trigger”,
“topic”: “z2ha/0x2FFA/state”
I’m not entirely sure if the topic or structure is correct. Any insights or debugging tips would be greatly appreciated!
3. Simplifying Light Automation with Blueprints
As a relatively new user to Home Assistant, I’ve been experimenting with creating custom blueprints for lighting automation. My goal is to streamline the process of setting up profiles like ‘Bright’, ‘Dimmed’, and ‘Night-Light’ for different times of the day. Here’s a simplified version of the blueprint I’m working on:
yaml
blueprint:
name: Custom Light Automation
description: Simplified light automation with predefined profiles
domain: script
input:
target_lights:
selector:
target:
entity:
domain: light
profile_input_select:
selector:
entity:
domain: input_select
sequence:
- choose:
- conditions:
- condition: state
entity_id: !input profile_input_select
state: Bright
sequence:
- service: light.turn_on
data:
brightness: 255
color_temp: 153
target: !input target_lights
- conditions:
- condition: state
state: Dimmed
sequence:
data:
brightness: 175
color_temp: 500
I’m still tweaking the logic, especially around state transitions and ensuring smooth automation. If anyone has suggestions or has successfully implemented a similar setup, I’d love to hear their experiences!
4. Debugging Raspberry Pi Hass.io Issues
I recently migrated my Home Assistant setup to a Raspberry Pi 5, and while most things are running smoothly, I’m encountering some automation failures. The logs indicate that the device IDs have changed, but recreating the automations hasn’t resolved the issue. Here’s an example of one of the failing automations:
yaml
alias: Front Light Sunset
triggers:
  • trigger: sun
    event: sunset
    offset: “-00:30:00”
    conditions:
    actions:
  • type: turn_on
    device_id: 7448696ccd73a84e00f3bdbae0e19f3f
    entity_id: d05e45e8bf6352728c7ba32cc8c03a6a
    domain: switch
The devices work fine through the dashboard and Alexa, but the automation isn’t triggering as expected. I’m wondering if there’s a specific configuration step I’m missing or if there’s a known issue with device ID handling post-migration. Any advice would be fantastic!
5. Final Thoughts
It’s been an exciting journey exploring the capabilities of Home Assistant and integrating various smart devices. While there are certainly challenges, the community support and endless customization options make it all worthwhile. I’m looking forward to continuing this journey and learning more along the way!
If anyone has encountered similar issues or has tips to share, please feel free to chime in. Let’s keep the discussions flowing and help each other optimize our smart homes!
Best regards,
