Optimizing Voice Command Latency in Home Assistant
As a homeowner who relies heavily on voice commands to control my smart home, I’ve recently noticed some delays, particularly when starting timers or adding items to my shopping list. This has been a bit frustrating, especially when I’m trying to multitask in the kitchen. I’ve been using Voice-PE with OpenAI and have around 70 entities exposed. While turning plugs or lights on/off is instantaneous, calling intents or starting timers feels sluggish. I decided to dig deeper and share my findings and solutions with the community.
Initially, I thought the issue might be with my Home Assistant setup. I tried switching from OpenAI to Home Assistant Cloud, but the improvement was minimal. Moving my HA instance from a HyperV VM to a more powerful desktop machine also didn’t help. I even considered upgrading my hardware, but that felt like overkill for a software issue.
I started by checking the logs using the debug logger, but the sheer volume of data made it hard to pinpoint the exact cause. I realized I needed a more targeted approach. After some research, I found a tool called Latency Checker that helped me identify where the bottleneck was occurring. It turns out the delay was primarily in the interpretation phase, where HA was taking too long to process the command before executing it.
Here’s what I did to improve the situation:
  1. Optimized Entity Configuration: I reviewed my entity configurations and removed any unnecessary attributes or complex automations that might be slowing things down.
  2. Enabled Local Processing: I made sure that as many commands as possible were processed locally on my HA server rather than relying on external APIs.
  3. Updated Firmware: A quick firmware update on my smart devices ensured everything was running on the latest stable versions.
  4. Reduced Network Load: I noticed that my network was slightly congested, so I adjusted my router settings to prioritize HA traffic.
The results were promising! Timers now start almost instantly, and adding items to my shopping list is much smoother. I’m still experimenting with different configurations, but the overall experience has improved significantly.
If anyone else is struggling with latency issues, I’d recommend starting with the Latency Checker tool and systematically testing each component of your setup. It’s a bit of a detective game, but it’s worth it to get that seamless smart home experience we all crave.
Happy tweaking, and feel free to share your own tips or tools in the comments below!
