Hi all, I’ve been diving deep into optimizing my Z-Wave setup lately and wanted to share some of my experiences and questions. [
The Challenge:
I’ve been using Z-Wave devices for a while now, but I’ve hit a few roadblocks. One thing I’m really curious about is how to effectively integrate multiple Z-Wave relays for landscape lighting. I have several zones I want to control, but the number of individual relays needed seems overwhelming. I’ve come across devices like the Enerwave ZWM-RSM2, but they’re designed for 120VAC loads, and I’m working with 12VAC. Does anyone have experience with low-voltage Z-Wave relays or know of any upcoming solutions? The Fortrezz MIMO sounds promising, but it’s still not available.
The Solution Journey:
I’ve also been exploring Chris Jackson’s Z-Wave device database to make informed purchases. It’s been super helpful in identifying devices that support polling for current states, which is crucial for my setup. However, I’m still unclear on how to determine if a device can report its state in real-time. If anyone has tips on this, I’d love to hear them!
A Success Story:
On a positive note, I recently tackled a signal strength issue with my Z-Wave setup. My house has thick concrete walls, so reception was spotty at best. After some research, I decided to modify an Aeotec Z-Wave stick by adding an external antenna. The process was a bit nerve-wracking, but the results were amazing! I carefully soldered an SMA connector to the internal antenna, added a ground wire, and secured everything with epoxy. The difference in reliability was night and day. If anyone else is struggling with signal issues, I highly recommend exploring this DIY approach! [
Looking Ahead:
I’m also curious about others’ experiences with Z-Wave device compatibility and integration. Have you encountered any unexpected issues or found creative solutions? I’d love to hear about your setups and any tips you have for optimizing performance.
Thanks for reading, and I look forward to hearing your thoughts! [
