Orbit Iris Water Timer Valve Noise Issue and Solutions
Hi everyone, I’ve been using the Orbit Iris Water Timer Valve for a while now, and I’ve noticed something that’s been a bit of a nuisance. The valve seems to make a pretty loud popping sound when it opens and closes. I’ve checked online, and it seems like this is somewhat common, but I wanted to see if anyone else has experienced this and if there are any solutions or workarounds.
After a bit of research and some trial and error, I found that adjusting the water pressure can help reduce the noise. I also came across some suggestions about using pipe insulation or padding around the valve to dampen the sound. It’s definitely something that could use some improvement, but for now, these fixes have made it more manageable.
On a different note, I’ve been working on integrating my Shelly Dimmer 2 into my home automation setup. It was a bit of a challenge at first, but I managed to get it connected and working smoothly with my system. I wanted to share my experience in case anyone else is looking to do something similar. The key was ensuring that all the firmware was up to date and that the network settings were optimized for stability.
Another thing I’ve been exploring is how to configure my lights for better compatibility with Google Assistant. I’ve found that grouping lights by room and using consistent naming conventions makes voice control much more seamless. For example, saying, ‘Hey Google, turn on the kitchen lights’ works perfectly when all the kitchen lights are grouped under a single entity. It’s a small tweak, but it makes a big difference in usability.
I’d love to hear your thoughts and experiences with these devices and any other tips or tricks you’ve picked up along the way. Let’s keep the conversation going!
Best regards,
