I recently completed an outdoor LED flood light control project that I wanted to share with the community. The goal was to create a system that provides high-quality lighting for security and visibility while being energy-efficient and easy to manage through Hubitat. Here’s a breakdown of the project and how it came together:
Project Overview
I wanted a lighting system that could handle both perimeter security and porch lighting. The system needed to be triggered by motion sensors and have built-in safety features to prevent energy waste. After researching various components, I decided to use a combination of Z-Wave and Zigbee devices to ensure compatibility and reliability.
Components Used
- Outdoor Dual Channel Z-Wave Receptacle: This serves as the control hub for the system.
- IP65/66 Rated LED Flood Lights: I opted for a 150W main floodlight for the football field-style lighting and a smaller porch floodlight.
- Z-Wave PIR Motion Sensors: These are placed strategically around the property to detect motion.
- Retro-Reflective Photo Beam Sensor: Modified for this project to provide additional trigger points.
- Weatherproof Extension Cord Protectors: Essential for outdoor wiring safety.
- GFI Outlet: Ensures safety by preventing electrical hazards.
Operation
- Perimeter Motion Detection: The retro-reflective sensor triggers the main floodlight when someone approaches the property. It stays on for 2 minutes before turning off.
- Closer Range Motion: A second PIR sensor activates the floodlight when someone gets closer to the house, also with a 2-minute runtime.
- Porch Lighting: A third PIR sensor triggers the porch floodlight for 2 minutes when motion is detected on the porch.
- Energy Management: The system uses both software-based timers in Hubitat and hardware timers on the outdoor outlets to ensure lights turn off automatically. Sunrise and sunset times are also factored in to avoid unnecessary lighting during daylight.
Challenges and Solutions
- Current Calculations: Ensuring the outlets and extension cords could handle the wattage was crucial. I recommend consulting an electrician if unsure.
- Weatherproofing: All components were selected for their IP65/66 ratings to withstand outdoor conditions.
- Safety First: The GFI outlet was a non-negotiable to prevent electrical hazards.
Why I Chose Hubitat
Hubitat’s rule-based system made it easy to create complex automation without needing extensive coding knowledge. The ability to integrate multiple sensors and outlets seamlessly was a game-changer. Plus, the sunset/sunrise integration ensures the system operates efficiently without manual intervention.
Lessons Learned
- Component Quality: Invest in weatherproof and energy-efficient devices to ensure longevity.
- Safety First: Always prioritize electrical safety with GFI outlets and proper wiring.
- Automation Flexibility: Hubitat’s platform allows for easy adjustments and expansions as needed.
Conclusion
This project has significantly improved my home’s security and outdoor lighting setup. It’s been a rewarding experience to see how various technologies can work together to create a reliable and efficient system. I hope this inspires others to tackle similar projects!
If anyone has questions or suggestions, feel free to reach out. Happy building! ![]()
