I recently set up my Hue Outdoor Motion Sensor with ZHA and SkyConnect, and I must say, it’s been a fantastic addition to my smart home setup!
While the illuminance, occupancy, and temperature readings are working perfectly, I noticed that the motion detection wasn’t registering as expected. After some research and tweaking, I found that adjusting the sensitivity settings made a world of difference! Now, it reliably detects movement, even in low-light conditions. ![]()
For those looking to integrate multiple devices or brands, I highly recommend exploring the ZHA integration within Home Assistant. It’s incredibly versatile and allows for seamless communication between different devices. ![]()
Another tip I’d like to share is about energy monitoring. If you’re using a smart switch like the S1 panel with a 3-gang setup, ensure that you’ve configured the energy monitoring channels correctly. This allows you to track power consumption in real-time, which is invaluable for optimizing energy usage. ![]()
Lastly, if you’re dealing with quirky devices like the Shelly Blu RC-4, don’t hesitate to reach out to the community for support. There are some brilliant blueprints and scripts available that can help you customize the functionality to suit your needs perfectly. ![]()
Overall, the journey of setting up and integrating these devices has been both challenging and rewarding. It’s amazing how a little troubleshooting and creativity can transform your living space into a smart, efficient haven! ![]()
