Outdoor sensor for windows roller shutter movement
Can I make use of any existing sensor to automate the opening/closure of my motorised windows roller shutters?
My house is exposed from all sides therefore especially in summer, it gets sun and heat through the day.
The roller shutters (over 20) are all equipped with smart switches, and at the moment I have time driven automatism in HomeKit to close or partially close the ones on the side where the sun is, theorigh the day, and then reopen them once the sun has changed side.
It’s effective for indoor temperature control.
However I’m thinking if I can make use of any existing sensor (eg temperature/light) to further fine tune such movements, so that the shutter is closed only when the sunlight hits directly, for example.
In cloudy or rainy days, my automatism is not helpful, for example…
@gabrieledv It sounds like you’re looking to optimize your roller shutter automation for better energy efficiency and comfort. Based on the reference information, you can indeed enhance your setup using specific sensors.
For your scenario, you could consider using the Aqara Motion and Light Sensor P2. This sensor can automate your shutters based on light intensity. For example, you can set it to close the shutters when the brightness exceeds a certain threshold, which is perfect for sunny days. This setup ensures your shutters only close when the sunlight directly hits, and remain open on cloudy or rainy days, thus providing a more dynamic and responsive solution compared to time-based automation alone.
The setup would involve integrating the Motion and Light Sensor P2 with your existing smart switches through a compatible hub, like the Hub M3, and configuring automation rules to respond to the light conditions.
Feel free to ask more questions or share your thoughts on how this could be further tailored to your needs!
Thank you!
@gabrieledv You’re very welcome! I’m glad you found the information helpful. If you have any more questions or need further assistance as you optimize your roller shutters, feel free to reach out. Your journey towards a smarter home setup is exciting, and we’re here to support you every step of the way. Happy automating!
