I’ve been absolutely thrilled with my SmartThings Hub v2, but recently I hit a bit of a snag that had me scratching my head. Let me share my experience in case it helps anyone else out there!
The Issue:
I misplaced my welcome code and after resetting my hub, I was stuck because it required the code to complete the setup. I tried reaching out to Norwegian support, but unfortunately, they couldn’t assist me directly. At first, I felt a bit defeated—was my hub now just a paperweight?
The Solution:
After some research and a bit of persistence, I discovered that SmartThings hubs have a built-in recovery feature! By holding down the reset button for about 10 seconds, the hub enters recovery mode and generates a new welcome code. It was such a relief to see it work seamlessly!
What I Learned:
This experience taught me the importance of keeping backup codes handy, but it also highlighted how resilient these devices can be with a little troubleshooting. I’m now a believer in digging deeper into device settings before giving up!
If anyone else finds themselves in a similar situation, don’t despair! The recovery process is straightforward once you know about it. And if you’re ever stuck, remember—there’s always a workaround if you’re willing to explore!
Happy automating! ![]()
