I recently came across a discussion about the blue light reflection issue with the Pan Cam V3. It seems that some users, like my MIL, are experiencing anxiety due to the blue light reflecting off objects like downspouts or the ground. I wanted to share my experience and some tips that might help others facing the same issue.
First, I understand that the blue light is coming from the camera itself, which can be a bit unsettling. I reached out to the support team, and they mentioned that while there isn’t a direct option to turn off the blue light, there are some workarounds. For instance, adjusting the camera’s position or angle can minimize the reflection. I tried this and noticed a significant reduction in the blue light visibility.
Another thing I found helpful was using a privacy filter or cover for the camera. This not only reduces the reflection but also adds an extra layer of security, making it less obvious that the camera is active. I’ve heard from other users that this simple tweak can make a world of difference.
If you’re still experiencing issues, I’d recommend reaching out to the manufacturer or checking forums for the latest updates or firmware patches. Sometimes, these issues are addressed in newer versions of the software.
In summary, while the blue light reflection can be a bit of a nuisance, there are practical solutions to mitigate it. By adjusting the camera’s position, using privacy covers, or staying updated with firmware, you can enjoy the benefits of your Pan Cam V3 without causing unnecessary concern for your family or neighbors.
Have you encountered similar issues? I’d love to hear your thoughts or any additional tips you might have!
