Panel Hub S1 Plus + Video Doorbell G400: best setup and recommendations?
Hi everyone,
I’m planning to combine an Aqara Panel Hub S1 Plus with the Aqara Video Doorbell G400 (video intercom) and I’d love to hear from people who already run this setup.
A few questions:
  1. Does the G400 live video show up reliably on the S1 Plus when someone rings the bell? How long is the delay, and can you answer / talk from the panel?
  2. Which setup works best: S1 Plus as the main hub with the G400 connected to it, or a separate hub (M100 / M3 / G5 Pro) in the middle? Any pitfalls?
  3. Can the bell press also trigger other things from the panel (chime, lights, a relay to open the door)?
  4. I mainly use Apple Home. Is there anything to keep in mind when using the S1 Plus and the G400 together with HomeKit / Matter?
  5. Any tips on placement, recommended automations, or firmware versions to avoid?
Thanks in advance, and photos of your setup are very welcome!
@pablobarros80 Great setup you’re planning! The Panel Hub S1 Plus and G400 combo can be really powerful. Let me share what I found from the reference info to help you out.
1. Live video on the S1 Plus when ringing
The S1 Plus can indeed auto-display the G400’s live feed when the doorbell is triggered — that’s one of the documented automation scenarios. However, the reference specifically mentions the G4 for this intercom-style behavior, not the G400. The G400 operates differently: it’s a Wi-Fi doorbell with its own chime repeater and doesn’t require an Aqara hub to pair. Whether the S1 Plus can pull live video from the G400 directly for two-way talk isn’t clearly documented, so I’d verify this with someone running the actual combo.
2. Hub topology
The G400 doesn’t need a dedicated Aqara hub at all — it connects directly to your Wi-Fi via the included chime repeater. So the S1 Plus would be a parallel device on your network, not a parent hub for the G400. The S1 Plus itself functions as a Zigbee hub and Matter bridge for your other Aqara gear. No need for an M100/M3/G5 Pro in between unless you want Thread/Matter routing for other devices.
3. Bell press automations
The S1 Plus supports automations with “IF Video Doorbell G4 is triggered”, so similar triggers should work for the G400 in Aqara Home — chimes, lights, relays. The G400’s chime repeater also has a menu button for local bell/alarm control. For door-opening relays, you’d likely need an Aqara relay or smart lock in the automation chain.
4. Apple Home / Matter considerations
The S1 Plus acts as a Matter Bridge to bring Aqara Zigbee devices into Apple Home, Alexa, Google Home, etc… The G400 itself has HomeKit support with live view, two-way audio, and doorbell press notifications. One thing to watch: the G400’s radar sensitivity defaults to conservative settings for HomeKit users to preserve battery, which can cause missed events — you may want to adjust “Lingerer Detection” in Aqara Home if you notice gaps.
5. Placement & automations
  • The G400’s chime repeater needs power and decent Wi-Fi; place it strategically between your router and doorbell
  • Consider the “Secure Welcome Home” automation pattern: doorbell trigger → panel shows video instantly
  • The G400 supports facial recognition triggers for personalized automations if you want advanced setups
Firmware note: I don’t have specific versions to avoid in the reference data — worth checking recent community threads for any G400-specific issues.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
Anyone here actually running the S1 Plus + G400 combo? Would love to hear real-world latency numbers and whether two-way audio works smoothly from the panel
