Hello everyone, I wanted to share my recent project integrating Particle Photon with an RGB lighting setup. It’s been a fantastic journey, and I hope this guide can help others who might be interested in a similar project.### Project OverviewI’ve always been fascinated by the idea of controlling RGB lights through a smart home system. After researching various options, I decided to go with the Particle Photon due to its affordability and versatility. The goal was to create a cost-effective RGB lighting solution that could be easily integrated into my SmartThings setup.### Materials Needed- Particle Photon/Core: Available for around $20 from the Particle Store.- WS2812B RGB Light Strip: I recommend this 30 LED/meter strip for its brightness and flexibility.- Breadboard or Soldering Iron: For wiring and testing.- Power Supply: Ensure your power supply can handle the amperage required for your setup.### Setup Guide1. Wiring: - Ground Wire: Connect the ground wire on the light strip to the ground pin on the Photon. - Data Line: Attach the data line from the strip to D2 on the Photon. - Power Supply: Connect the +5V line on the strip to the VIN pin on the Photon. If you’re using an external power supply, ensure it’s compatible with the Photon’s voltage requirements.2. Firmware Installation: - I developed a custom firmware to interact with the Photon and control the RGB strip. The code is available on GitHub, complete with detailed instructions for setup and customization.3. SmartThings Integration: - Once the firmware is installed, the Photon communicates seamlessly with SmartThings. You can set up custom scenes, color transitions, and even integrate music-sync functionality for a dynamic lighting experience.### Challenges and Solutions- Power Management: Initially, I faced issues with power supply management. By calculating the required amperage based on the length of the strip, I ensured stable operation without voltage drops.- Firmware Customization: While the initial code worked, I wanted more flexibility. This led to the development of a customizable RGB color wheel, allowing for endless lighting combinations.### Results and FeedbackThe outcome has been nothing short of amazing. The RGB strip provides vibrant, customizable lighting that enhances both my living space and home theater experience. The ability to control everything through SmartThings has added a new level of convenience and enjoyment.### Future PlansI’m excited to expand this project further. My next steps include:- Adding more zones for comprehensive lighting control.- Incorporating voice commands for even greater ease of use.- Exploring more advanced programming features to enhance the lighting effects.### Final ThoughtsThis project has been a rewarding experience, combining hardware hacking with smart home integration. It’s a testament to what you can achieve with a bit of creativity and determination. I’d love to hear your thoughts and see how you might adapt this setup for your own projects!Happy tinkering! ![]()
