Permanent Outdoor Lights H1: anyone have specs, photos or hands-on info?
Hi all,
I’m planning to put permanent lighting on my house this autumn. The Aqara Permanent Outdoor Lights H1 look like they’re coming out soon, but I can’t find any documentation, photos or a proper feature list. Before I commit (and before I buy a competitor instead), I’d like to know what we’re actually getting.
If you’ve seen a spec sheet, a trade-show demo, a beta unit or an official answer from support, please share it. I’ll collect every answer into a summary in this first post so the next person doesn’t have to dig.
Hardware and installation
What does the system actually include? What’s the spacing between pods?
How far can it be extended? Is there a maximum run per controller or power supply, and do extension kits need their own power injection?
Can a run be cut or shortened, or only extended in fixed segments?
How does it mount: channel or track, clips, adhesive? Is the track included?
What’s the IP rating, and what’s the operating temperature range? I’m in Estonia, so I need to know how it handles -25 °C, snow and ice.
If one segment or pod fails, can you replace just that part?
Light output
Are the LEDs individually addressable (per LED, per pod, or only per segment/zone)?
How bright are they (lumens per meter or per pod)? Is there a proper white channel (RGBW/RGBWW) or only mixed RGB white?
What’s the color-temperature range for white, and how does the white look in real life: warm and natural or bluish?
How low can it dim? Is 1% dimming smooth enough for subtle all-year accent lighting?
Power
What’s the power consumption at full brightness, and per metre? What’s the standby draw?
Where does the PSU go? Is it rated for outdoors, and what’s the cable length from the PSU to the first light?
Smart home and control
Does it work fully locally (Home Assistant), or does it depend on the cloud?
Integration with Home Assistant, Apple Home, Google or Alexa: are individual segments or effects exposed, or just one on/off/color entity?
Are there built-in effects or scenes (holidays, animations)?
Can you schedule it by sunset/sunrise without an app or cloud service?
Buying
Price, EU availability and release date?
Warranty length? Is there a planned firmware update path?
For comparison, the other options I’m looking at are Govee Permanent Outdoor Lights and a DIY WLED setup. If the H1 is local and addressable with decent white, it’s probably my pick.
Thanks in advance. I’ll keep this post updated with everything we learn.
Unfortunately I think anybody who did have details they could share would still be under NDA at this point.
Following because I’m interested as well
