PF300 Stays dormant
I have had several issues while trying to find the right combination of settings to make the presence sensor work for my needs. I placed the sensor in my garage right in front of the access door.
I changed the sensitivity to maximum, changed it to be on Zigbee as the M3 hub is a mere 10 feet away. I also changed it to mmWave for it to be more sensitive.
Unfortunately, it has become dormant at times. Even by going into the app and restarting it. Still shows in a “Absence” state. They only way is to test the automations several times and then it begins to detect. I have removed and readdress the automation and tested.
Not sure how I can prevent this from happening going unresponsive.
Hi @rlainez70 did you use the latest iOS 26 ? It’s possible that it stays in the Absence status . But reset it and add it again in Zigbee mode- then I also would recommend to set the dual mode - Infrared Radar Dual Presence mode.
Let me know if it works now
I tried and it was working fine but now it is lagging again.
Going to rest again and see if it resolves anything.
Just wished it would just work.
