Philips Hue Color Control Issue Solved
I recently encountered an issue while trying to control my Philips Hue LED strip via OpenHAB rules. The problem arose when I attempted to switch between different color modes and color temperatures. After some experimentation, I discovered that once the color temperature mode was activated, it became impossible to revert back to the color mode using the predefined buttons in my setup. This was quite frustrating as it limited the functionality of my smart lighting system.
To address this issue, I decided to modify my rule to ensure a smooth transition between modes. Here’s how I resolved it:
  1. Identify the Problem: The Hue strip would get stuck in color temperature mode, preventing any further color changes.
  2. Modify the Rule: I added a step in my rule to explicitly set the color mode before applying any color changes. This ensures that the strip exits color temperature mode before receiving new color commands.
  3. Test the Solution: After implementing the changes, I tested the buttons to confirm that they now switch seamlessly between colors and color temperatures without any issues.
Here’s a snippet of the modified rule for reference:
java
rule “TV_Backlit_Colors_rule”
when
Item EGWZFernseherColorValues received command
then
if (receivedCommand == 1) {
// Switch to color mode
FernseherEffect.sendCommand(OFF)
// Set color to red
var HSBType light = new HSBType(0, 50, 100)
FernseherColor.sendCommand(light.toString)
// Add similar cases for other colors
end
This adjustment ensures that the Hue strip always starts in color mode before any changes are applied, preventing it from getting stuck in color temperature mode. I hope this solution helps anyone else facing a similar issue with their Hue setup!
If you have any questions or alternative solutions, feel free to share them below. Happy automating! :slight_smile:
