I’ve been diving into the world of smart home automation, and it’s been an incredible journey! One of the most exciting projects I’ve undertaken is setting up a Philips Hue Gradient Lightstrip for my 27-inch monitor. While the process has been smooth overall, I wanted to share my experience and ask for some advice from the community.
My Setup
I’m using a 27-inch Samsung monitor (LS27DG602SUXUF) and wanted to create an ambilight-style setup using the Philips Hue Gradient Lightstrip. Unfortunately, the 24–27 inch Hue Gradient version is no longer available in my country, so I opted for the 2-meter Gradient Lightstrip instead.
Here’s how I planned to install it:
- Wrap around the left, top, and right sides
- No bottom coverage
- Fold the excess length on the top back side of the monitor
Questions & Concerns
- Is the 2m strip too much for a 27” monitor? I’m curious if this setup is common or if there’s a better way to achieve the desired effect.
- Will folding the excess strip affect performance? I’m worried about how this might impact the gradient smoothness or Hue Sync functionality.
- Any potential downsides? I’d love to hear if anyone has experienced issues with similar setups.
What I’ve Learned So Far
- Placement Matters: The way the strip is positioned can significantly affect the lighting effect. I’m still experimenting with the optimal placement to ensure even coverage.
- Folding the Strip: While it’s a bit tricky, folding the excess length seems manageable. I’ll update the community once I’ve finalized the setup!
Looking for Feedback
If anyone has experience with a similar setup or has tips for optimizing the Gradient Lightstrip, I’d be thrilled to hear from you! Real-world experiences and advice would be invaluable as I fine-tune this project.
Let’s make this setup as seamless and effective as possible! ![]()
Cheers,
