Hey everyone, I’m really excited to share this awesome solution I found for controlling my media devices with the Philips Hue Tap Dial using Zigbee2MQTT (Z2M) in Home Assistant. This blueprint is a game-changer for anyone looking to customize their media controls without any coding hassle!
What It Does
This blueprint allows you to use the Hue Tap Dial wheel for volume control and fully customize the actions for the 4 buttons—both short and long presses. Whether you want to skip tracks, toggle playback, or even trigger custom automations, this setup makes it incredibly easy.
Features I Love
- Volume Control: The dial works smoothly for adjusting the volume. It even supports different rotation speeds—step, slow, and fast—so you can fine-tune how sensitive it is.
- Custom Button Actions: Short and long presses on each button can be set to trigger any action you want. For example, I’ve set mine to play/pause, next track, previous track, and toggle mute.
- User-Friendly Setup: The blueprint walks you through selecting your media player, setting volume steps, and configuring button actions. It’s super intuitive!
How to Get Started
- Import the Blueprint: You can directly import it from the link provided in the original post. It’s optimized for the latest syntax and supports both English and other languages.
- Configure Your Settings: Choose your media player, set your preferred volume range, and define what each button does. The setup is entirely within the Home Assistant interface, so no external files or complex configurations are needed.
- Test and Enjoy: Once everything is set up, test it out! Rotate the dial to adjust the volume and press the buttons to trigger your custom actions. It’s incredibly responsive and reliable.
Tips for Customization
- Volume Sensitivity: If you find the volume changes too quickly or too slowly, you can adjust the step increments in the settings. This makes it perfect for different playback devices.
- Button Actions: Don’t limit yourself to media controls. You can set buttons to turn on lights, adjust scenes, or even trigger complex automations. The possibilities are endless!
Why This Matters
For anyone looking to enhance their Home Assistant setup with a sleek, customizable media control solution, this blueprint is a must-try. It combines the elegance of the Hue Tap Dial with the power of Z2M and Home Assistant, offering a level of customization that’s hard to find elsewhere.
If you’ve been wanting to dive into automations but haven’t found the right starting point, this is it! Give it a try and let me know how you’ve customized it in the comments. Happy automating! ![]()
