Hello, I want to put Aqara G400 on the front door when it’s on sale, but it’s not clear which power supplies to put. Couldn’t you say the voltage and currents consumed by this model?
Hi , as far as I know a POE cable connection would be best and most stabil - So I would use a Cat cable if its possible
See the infos on reddit
CAT cable is ok, there’s no specific cable for PoE, I recommend you at least a CAT5e.
Make sure you’re router or switch can send also power through LAN cable.
Best bet here is a poe, just pull it along the current 12V line or see if you can put CAT5e in the powerline tubes
