I switched my FP300 to Zigbee and paired it with Zigbee2MQTT 2.14 in Home Assistant to turn on my office light. It works well so far. How are your experiences with battery life and the presence detection settings in Zigbee mode? Any recommended values for sensitivity and absence delay?
@marco_reetz Great to hear your FP300 is running smoothly with Zigbee2MQTT! On battery life, the FP300 is rated for up to 3 years in Zigbee mode under ideal conditions—though real-world results depend on your reporting frequency, trigger rate, and which sensors you keep active. Since you’re just using presence for lighting control, you’ve got a good shot at hitting the longer end of that range.
For Zigbee mode settings, the Aqara Home app gives you solid control: detection mode/range adjustments, independent sensor toggles, and the absence delay timer you asked about.
My quick take on tuning:
- Sensitivity: Start medium-high for an office—you want reliable detection during focused work (subtle movements), but not so high that HVAC or desk fans trigger false positives. The AI interference filtering helps over time.
- Absence delay: 10–30 seconds works well for lighting. Shorter feels snappier but can cause annoying flicker if you sit still; longer is more forgiving but delays off.
If you do hit false positives, the AI Background Learning feature can recalibrate things quickly.
What’s your current absence delay set to? Curious how it’s performing in practice.
HI @marco_reetz
This sensor actually works quite well; the sensitivity settings need to be adjusted for each specific case, depending on the room and the intended tasks. Therefore, it is best to experiment with the settings yourself to find the configuration that works best for your needs.
