I would like to change the protocol in my dimmer switch H2 Eu from Matter to Zigbee. I have the deivice paired to my Hub M3 via Matter today. It is connected with neutral.
When i reset the device and choose the change protocol to Zigbee in the add device procedure, it first transfers the firmware to 100% and then cange protocol to 99%, then i get a process interupted error.
when I try again i often get a error code 6 already at the transfer firmware process. All operations are done in Aqara home for IOS.
Any ideas?
@dag11 Welcome to the forum!!!
Hey there and welcome to the forum.did you delete it from Aqara home app entirely meaning that it doesn’t show on accessories ?also make sure you phone is on same network as the M3 and if you had it added to apple home app delete it as well and make sure your M3 is not to far from the switch.last check if you have this option On or Off on the M3 as if is On the switch it off
Have you tried rebooting the dimmer by turning the breaker off and on (after 10s)?
The device is compeltly gone from the Home app. Phone and M3 are on the same wifi. I do not use the Apple home app so its not there. I have moved my M3 to 10 cm from the dimmer. The accidental removal switch is off. I have tried to the dimmer off with the breaker. Nothing seems to work.
Well today o receive an update for Aqara home app my be this will fix your issue as from what you mention I do not think that is the switch the problem.so update your Aqara home app and then try again.if not you should also contact Aqara support and tell them this issue so they can investigate it
Updated app to latest version. No change.
The dimmer is located in my summer cottage on a tiny island and today I closed it and put the boat in storage for the winter. Next test will be at easter weekend.
Ok and the M3 is there too?because if is to far from it then that makes it do disconnect from the Aqara home app and for that you need to add 1/2 zigbee bridges more depending on the distance
Haha, that’s a long wait
there will be lots of updates till then so I hope it will just work when you are back next year
Yes the M3 is there too. Thats one of the reasons I went for the M3. It works perfectly without a stable internet connection but when the internet are up I still can monitor and make adjustments. i guess that in theory I could have contiued to test with add and change protocol, but without physical access for restarts etc I let it be. I have no needs to adjust the dimmer from Home anyway.
Yes agree if you can access it and is working why stressing to change protocol.
I had similar problems with the H2EU smart plug. Because the nearest matter hub was too far away in my 16C stone-built italian tower, I wanted to.use it with my Zigbee G3Camera hub, which jusymt over 2M away. I struggled and struggled to get it to pair with a zigbee device. Even with multiple resets and so on. Eventually I got it to pair with the G3.
Unfortunately, an hour or so later it dropped the Zigbee connection and reverted to Matter, but, of course, could not pair with the remote hub.
I suspect that this series of matter devices may well be using the same chip and similar core firmware. You may be a victim of the inherent Matter preference.
I returned mine.
