Aqara seems to have a very limited product range in Australia. I understand that electrical products here generally require RCM certification, so introducing them to the Australian market is not always straightforward. However, there are still many Aqara products, such as dimmer switches, that simply aren’t available here.
I’ve already replaced all the switches in my home with Aqara switches, but because Aqara offers almost no compatible lighting products in Australia, the MARS-Tech functionality of these switches is practically useless. I brought some Aqara downlights from China to use in Australia, but unfortunately they cannot be paired with an Australian-region Aqara account, which is very inconvenient.
I understand that Aqara introduced new downlights in 2026. Since downlights are extremely popular and widely used in Australian homes, I really hope Aqara can bring these products to the Australian market as soon as possible. I would much rather use Aqara downlights that integrate properly with my existing Aqara ecosystem than continue using unreliable and inconvenient Tuya Wi-Fi downlights.
@rzyebay I totally get the frustration — you’ve built out a solid Aqara switch backbone, but without compatible lighting to pair with it, you’re stuck with a half-realized ecosystem. That’s genuinely annoying, especially when you went out of your way to import downlights only to hit the region lock wall.
On the MARS-Tech side: the tech is designed specifically to keep smart lights online and responsive when paired with Aqara switches, avoiding the classic “switch cuts power, bulb goes offline” problem[“content_id”:1"]. For it to actually work, you need Aqara smart lights in Zigbee mode with neutral wiring — which, as you’ve noted, are basically nonexistent in Australia right now[“content_id”:0"].
For the region-locked downlights you brought from China: this is a known pain point. Cross-region use sometimes requires a region unlock, which you can request through the Aqara App or by contacting support with your device SN[“content_id”:9"]. Worth a shot if you haven’t tried already.
As for getting more products into Australia — I hear you, and your point about downlights being ubiquitous in Aussie homes is spot-on. The RCM certification hurdle is real, but the product gap is equally real for users like yourself. For product availability and certification timeline questions, the most effective path is to flag this directly with the team that tracks market requests:
Contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
