Hello everyone! I hope you’re all having a great day. I wanted to share a question I’ve been pondering regarding radiant floor heating and ceiling-mounted thermostats. A friend is building a house and is considering placing ceiling-mounted Z-Wave temperature sensors. From my experience with HVAC systems, I know that a sensor in the ceiling often reports a much higher temperature than at body height. However, my friend believes that radiant floor heating might change this dynamic. I’m curious if anyone has insights or experiences to share on this topic.
Radiant floor heating is known for its efficiency and comfort, but the placement of temperature sensors can significantly impact how well the system performs. Ceiling sensors might not provide the most accurate representation of the occupied space’s temperature, especially in rooms with high ceilings. I’m wondering if others have encountered similar situations or if there are best practices for sensor placement in radiant heated spaces.
In my own setup, I’ve found that placing sensors at a comfortable height, around waist level, provides a more accurate reading that reflects the actual comfort of the room’s occupants. However, I’m open to hearing other perspectives or innovative solutions that others might have implemented.
If anyone has successfully integrated ceiling-mounted sensors with radiant floor heating, I’d love to hear about your experiences, challenges, and how you ensured optimal performance. Additionally, any tips or tricks for balancing sensor placement with system efficiency would be greatly appreciated!
Thank you all for your time and input. I look forward to learning from your experiences and insights!
