I’ve been diving into the world of smart home automation, and it’s been a fascinating journey! One thing I’ve noticed is that while automation makes life incredibly convenient, it can sometimes feel a bit too predictable. For instance, having lights turn on and off at the exact same time every day might be efficient, but it could also signal to potential intruders that the house is unoccupied.
This led me to explore ways to add some randomness to my automation schedules. I came across a few threads discussing similar ideas, and it inspired me to try something out. My goal was to create a system where lights would turn on and off at slightly random times within a set window, making it look like someone is home even when they’re not.
I started by looking into the Rule Machine Legacy rules, as they seemed flexible enough for this task. I set up a virtual switch to represent daylight hours, which I toggle on at sunrise and off at sunset. Then, I created two rules: one to turn the lights on with a random delay and another to turn them off with a similar delay. The idea was to have the lights cycle on and off every 5 minutes during daylight hours, but with a bit of randomness to avoid a strict pattern.
However, I ran into an issue where the switch would sometimes get stuck in the ‘on’ position, especially after sunset. It seems like the delays and randomization were causing some conflicts, and the system wasn’t handling the transitions smoothly. I tried adjusting the delays and even the logic behind the rules, but the problem persisted.
I’m curious if others have tackled this challenge and how they approached it. Have you found a reliable way to introduce randomness into your automation schedules? I’d love to hear about your experiences and any tips you might have for making this system more robust. Let’s brainstorm together and see if we can come up with a solution that works!
