I’ve been diving into the world of Raspberry Pi 4 with the 4GB model, and it’s been an exciting journey! My goal was to not only set up OpenHAB for my smart home but also to run additional services like a local web server for my Apache/PHP/MySQL stack, Node.js projects, and even PiHole for network-wide ad blocking. Initially, I was a bit worried about whether the Pi could handle all these tasks simultaneously without lagging, but I’m thrilled to share that it’s working beautifully!
After some research, I decided to go with virtualization to keep everything organized. Using tools like Docker and Proxmox, I’ve been able to create isolated environments for each service. This setup not only keeps my system stable but also makes it easier to troubleshoot and manage. I’ve even started experimenting with running a VPN server in a separate VM, which adds an extra layer of security to my network.
One thing I learned early on is the importance of proper cooling and power supply. I upgraded to a high-quality power adapter and added a small fan to keep the Pi cool, especially during extended usage. The performance improvement was noticeable, and I haven’t encountered any overheating issues since.
For anyone considering a similar setup, I’d highly recommend exploring virtualization options. It might seem a bit daunting at first, but the flexibility and stability it provides are well worth the effort. Plus, the Raspberry Pi community is amazing—there’s always someone willing to help if you run into any roadblocks!
Here’s to many more successful projects and learning opportunities with my Raspberry Pi 4! ![]()
