Raspberry Pi UI Access Issue with MQTT Running
Hi everyone, I’m facing a recurring issue with my Raspberry Pi setup, and I’m hoping someone can offer some insights or solutions. I’ve noticed that after performing a sudo reboot, the Raspberry Pi restarts as expected, but I’m unable to access the UI via port 8080 or the OH app. Interestingly, I’ve observed that the MQTT service is still running because when I physically toggle a switch, the action is recorded in the MQTT.fx subscribed topic. This suggests that the issue is isolated to the UI not rebooting properly or becoming inaccessible after the restart.
To resolve this, I’ve had to pull the power plug from the Raspberry Pi and replug it, which restores access to the UI. However, since I’m working on a remote installation, this isn’t always feasible. I’m wondering if there’s a way to force a system reboot from the MQTT.fx client monitor or another method that doesn’t require physical access. Any suggestions or troubleshooting steps would be greatly appreciated!
Thank you in advance for your help. Cheers, Chris
