Hey everyone, I wanted to share my experience and journey with integrating real-time cameras into Lovelace for a high-powered laser cutter monitoring system. I’ve been working on this project for a while now, and it’s been quite the learning curve! ![]()
So, the goal was to create a dashboard that displays real-time camera feeds, temperature readings, status updates, and various graphs all in one place. The cameras were set up using MotionEye, and when viewed directly through MotionEye, they looked fantastic and were completely real-time. But when I tried integrating them into Lovelace, everything started to lag, and the video quality dropped significantly. ![]()
I experimented with different camera platforms and Lovelace cards. I tried the Frigate card, thinking maybe it would handle the real-time aspect better, but unfortunately, it had the same issues. I even went as far as embedding an iframe with the MotionEye stream, which worked for real-time video but messed up the display controls, making the image look cropped and not as polished as I wanted. ![]()
After a lot of research and trial and error, I stumbled upon a solution that involved tweaking the camera settings within MotionEye and using a custom Lovelace card that allowed me to access the MotionEye controls directly. It wasn’t the most straightforward fix, but it got the job done! ![]()
This experience taught me a lot about camera integration in Home Assistant and the importance of experimenting with different setups. If anyone else is struggling with real-time camera feeds in Lovelace, I’d recommend checking out MotionEye’s settings and exploring custom Lovelace cards. You never know what might work until you try it! ![]()
Happy automating, and let me know if you’ve faced similar challenges or have any tips to share! ![]()
