Recent Aqara products
My latest aqara products are the Roller Shade Driver E1, I have them on every set of blinds in the house except the inset patio door blinds and the Aqara hub M3. If anyone has a suggestion on how to make inset patio door blinds “smart” I’m open to suggestions… there doesn’t appear a good way to mount the E1 driver, the Smart roller, to my understanding doesn’t go small enough and I don’t know whether it would fit in the Blinds2go frame mount? I did use the curtain drivers as well before in my old house but they don’t work on 16-19mm poles so I had to change to SwitchBot drivers. I’m curious about the fp400 kit. What do people use it for? Can it tell the difference between people based on height/mass etc etc?
@DPJ88 Great setup you’ve got going with the Roller Shade Driver E1s and the M3 hub! Sounds like you’re deep into the Aqara ecosystem.
For your inset patio door blinds, you’re right that the E1 driver and Smart Roller can be tricky with limited mounting depth. The Roller Shade Driver E1 uses double-sided tape or screws for mounting, but if the frame is too shallow or obstructed, that becomes a real headache. A few things worth trying:
  • Custom bracket or 3D-printed spacer: Some folks in the community have had luck with thin L-brackets to offset the driver slightly.
  • External mount: If the frame allows, mounting on the wall just above the recess rather than inside it.
  • For the Blinds2go frame: measure the tube diameter and clearance carefully. The Smart Roller’s housing might still be too bulky.
As for the fp400 kit — assuming you mean the FP2 (Aqara’s naming can be confusing!), it’s a millimeter-wave presence sensor with some pretty slick capabilities. It can detect presence, absence, falls, entering/leaving, approaching/moving away, and supports real-time tracking of up to 5 targets simultaneously[“content_id”:5"]. However, it doesn’t distinguish people by height, mass, or identity — it tracks positional data and movement states, not individual biometric profiles. So while you can see “someone is in zone 3” or detect a fall, you can’t get “Dave entered the room” vs “Sarah entered the room” based on body characteristics.
If you’re after person-specific identification, you’d need to layer it with other signals (like phone presence, NFC tags, etc.).
Hope that helps — would love to hear what you end up doing with the patio door
