Reducing false alarms with FP400 Trial
I had an ongoing issue with motion sensors in my Garage giving false alarms due to spiders moths and pets etc activating the current sensors. I was interested to trial the FP400 and was not disappointed, false alarms are no more and I have linked it to the lighting which only comes on when someone is present and the light levels are low. The only downside is that the sensor requires a 12V supply rather than batteries. - not a huge issue but worth bearing in mind when considering placement.
Hi there.why do you say that it requiere 12V from what I know only needs an 5V and 1A adaptor mine is connected to an 20w apple charger and works perfectly.ether way even if you add an 12v adapter the sensor takes only what he needs not the entire 12v.but you can add an apple charger to power it as well.ether way i am glad that it works perfectly for your setup.
