Reducing SD-Card Wear in Home Assistant Setup
Hello everyone,
I wanted to share my experience in reducing SD-card wear when running Home Assistant on a Raspberry Pi. As many of you might know, SD cards can wear out over time, especially with frequent writes from logs and system updates.
I started by looking into ways to minimize the strain on my SD card. One effective method I found was redirecting log files to a ramdisk. This way, the logs don’t get written to the SD card repeatedly. I also set up a USB stick for backups, which helps offload some of the write operations.
Here’s a quick rundown of what I did:
  1. Ramdisk for Logs: I moved the OZW_Log.txt file to a ramdisk. This prevents the SD card from being constantly written to by the log file.
  2. USB Backups: I configured my backups to use a USB stick instead of the SD card. This not only reduces wear but also provides a safe backup location.
  3. Regular Maintenance: I make sure to monitor the SD card’s health and plan to replace it every couple of years as a precaution.
This setup has been working great for me, and I’ve noticed a significant reduction in SD card wear. It’s a simple yet effective way to extend the life of your hardware!
If anyone has more tips or alternative solutions, I’d love to hear them. Happy automating! :rocket:
