Hello everyone, I wanted to share my experience with installing reed switches for my smart garage door setup. I’ve been using the ratgdo32 disco garage opener, which has been a great replacement for the older system that didn’t integrate well with my smart home setup.
I started by understanding how reed switches work—they rely on a magnet and a stationary plate to signal the opener when the door is open or closed. I opted for commercial-grade switches due to the harsh weather conditions where I live.
The challenge came with the physical installation. My garage door is segmented, and the motor is well over a foot behind the resting point of the door. Finding the right spot to mount the switches was tricky because they needed to align perfectly without any angle. After some trial and error, I realized that using the existing J bracket as a mounting point was the key. I attached the magnet to the door and positioned the stationary plate on the bracket, ensuring they were parallel.
I also wanted to share a tip for anyone facing similar issues: measure the distance carefully and use a level to ensure everything is aligned. If you’re unsure about the placement, temporary mounting hardware can help you visualize the setup before committing.
This project taught me a lot about problem-solving and the importance of a good plan. I hope my experience can help others who are looking to integrate reed switches into their smart home setups! Happy tinkering! ![]()
