Reolink Duo Flood Light Automation Issues
Hey everyone, I’m encountering an issue with my Reolink camera setup and the Duo Flood Light integration. I’ve been using the Reolink integration without any problems for other cameras, but when it comes to controlling the flood light, it’s been hit or miss.
Here’s the situation: I’ve set up an automation to turn the flood light on under specific conditions, but it consistently fails with a connection error. However, when I manually toggle the flood light through the UI, it works perfectly fine. The entity name is the same in both the automation and the manual controls, so I’m a bit puzzled about what’s going wrong.
I’m wondering if there’s something I’m missing in the configuration or if there’s a known issue with the flood light integration. Any insights or suggestions would be greatly appreciated!
Thanks in advance for your help!
