Replacing a Yale push button door lock
I’ve got an old Yale push button door lock that I want to replace with an Aqara smart lock. It’s for an exterior lock. Any ideas what would be the best one to go for?
@bobbywindebank Great question! Replacing a Yale push button lock with an Aqara smart lock depends a lot on your door’s setup and region.
From the Aqara lineup, the Smart Door Lock U200 is worth a close look if you’re in a market where it’s available—it’s designed specifically for retrofit scenarios and supports EU Mortise Locks, US Deadbolt Locks, and various cylinder types including Schlage and Kwikset standards. Since Yale push button locks often use standard deadbolt or mortise mechanisms, the U200’s compatibility range could cover your setup. You can check the exact installation requirements here: https://www.aqara.com/en/u200-installation-methods/.
For other options, the U300 offers a sleek full-replacement design with Matter support, while the U50 features a more streamlined button layout. The A100 (overseas variant) and D100 are also solid choices depending on your regional availability and whether you prefer a retrofit or complete replacement approach.
A few things to double-check before deciding:
  • Your door thickness and backset measurement
  • Whether your current lock uses a standard cylinder or proprietary Yale mechanism
  • Preferred unlock methods (fingerprint, keypad, app, etc.)
If you can share your region and a photo of your current lock’s interior mechanism, the community can help narrow it down further
Hi @bobbywindebank
If you can provide us some more :enqjol2bgmcitcrmcmgdyz_61: ( lock type) and pics , we definitely could better help you!
