Hi there! I came across your question about replacing push buttons with an Aqara H1 double rocker switch. That sounds like an interesting project! I’d love to hear more about how you’re planning to integrate it into your smart home setup.
If you’re looking to configure the Aqara H1 to act as a momentary push button, I’ve heard that it’s definitely possible with the right automation rules in Home Assistant. You might need to set up a script that triggers the action when the switch is pressed and then immediately resets it. This way, it mimics the behavior of a traditional momentary push button.
I’d recommend checking out the Home Assistant documentation or community forums for specific automation examples. They often have detailed guides on setting up custom behaviors for smart switches. If you’re comfortable with YAML, you can create a custom automation that listens for the switch press event and executes the desired action.
One thing to keep in mind is ensuring that the wiring is correctly set up to handle the momentary signal. Sometimes, a simple toggle switch might not provide the brief pulse needed for a momentary action, so double-checking the wiring configuration is essential.
If you run into any issues or need more specific guidance, feel free to share more details about your setup. The community here is really helpful, and I’m sure someone will be able to assist you further. Good luck with your project! ![]()
