Hi everyone,
I wanted to share a helpful tip that might save someone some frustration. Recently, our neighborhood experienced a power outage due to a damaged underground cable. When the power was restored, about half of our Tradfri lamps were reset, which was unexpected but luckily easy to fix using the ‘Maintenance’ function in the Homey Pro 2023 app.
Here’s what I did:
- Identify the Affected Lamps: After the power came back on, I noticed some lamps were not responding as usual.
- Access the Maintenance Function: I opened the Homey app and navigated to the ‘Maintenance’ section.
- Reset the Lamps: Using the maintenance tools, I was able to reset the affected lamps. This process was straightforward and only took a few minutes.
- Lamps Back to Normal: After the reset, all the lamps worked perfectly again.
I think it’s important to note that while power outages can cause issues with smart devices, many modern systems have features to help recover from such events. I hope this helps others who might face a similar situation.
If anyone has additional tips or experiences with resetting devices post-outage, I’d love to hear them!
Best regards,
