Resolving Alpha Vantage Sensor ImportError
I’m encountering an ImportError when using the Alpha Vantage sensor in Home Assistant. The error message is as follows:
python
Error while setting up platform alpha_vantage
Traceback (most recent call last):
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py”, line 82, in async_setup
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/lib/python3.5/asyncio/tasks.py”, line 400, in wait_for
return fut.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
File “/usr/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
result = self.fn(*self.args, **self.kwargs)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/alpha_vantage.py”, line 69, in setup_platform
from alpha_vantage.timeseries import TimeSeries
File “/srv/homeassistant/lib/python3.5/site-packages/alpha_vantage/timeseries.py”, line 1, in
from .alphavantage import AlphaVantage as av
File “/srv/homeassistant/lib/python3.5/site-packages/alpha_vantage/alphavantage.py”, line 17, in
from simplejson import loads
ImportError: No module named ‘simplejson’
I’ve tried installing simplejson using pip install simplejson, but the error persists. Could there be an issue with the installation or the Python environment? Any guidance on resolving this would be greatly appreciated!
