Resolving cifs Errors in Home Assistant
Hi everyone, I wanted to share my recent experience with resolving cifs errors in Home Assistant. After encountering endless cifs errors in my Proxmox VE shell, I found myself in a bit of a predicament. My system setup includes Home Assistant running as a VM on a Mini-PC under Proxmox 8.3.3. The errors were persistent, and even after reinstalling HA through a HelperScript and restoring a backup, the issue remained.
I tried configuring both Samba and NFS for network storage access, but the cifs errors persisted. After some research and troubleshooting, I discovered that the issue might be related to how the network shares were mounted. I decided to switch back to Samba and carefully review my configuration files.
Here are a few tips that might help others facing similar issues:
  • Ensure that all network shares are properly configured and accessible.
  • Check firewall settings to ensure that necessary ports are open.
  • Verify that the user permissions on the NAS are correctly set up for the Home Assistant user.
  • Consider increasing the logging level for cifs to get more detailed error messages.
After making these adjustments, the cifs errors significantly reduced, and my system has been running smoothly since. I hope this helps someone else who might be struggling with similar issues. Happy troubleshooting! :rocket:
