Hi everyone, I wanted to share my recent experience with integrating Homey with Google, as I encountered a few bumps along the way. Hopefully, this can help others who might be facing similar issues!
The Issue
Since updating my Homey setup, I noticed that the Google integration was sporadically dropping out. Restarting Homey didn’t seem to resolve the issue, and it was quite frustrating as I rely heavily on voice controls through Google Assistant.
The Investigation
I started by checking the logs and noticed that the integration would occasionally throw an ‘Internal Error.’ After some research, I realized this wasn’t an isolated issue—many users were experiencing similar problems, especially after updates. It seemed like a recurring theme where the connection would drop, requiring a full reboot of the router or modem to restore functionality.
The Solution
After experimenting with various troubleshooting steps, I stumbled upon a helpful suggestion in the forums. Someone mentioned that creating a custom flow to monitor the connection status and automatically attempt a reconnection if it drops could be a viable solution. This was a game-changer for me!
Here’s a quick rundown of what I did:
- Monitoring the Connection: I set up a sensor to track the status of the Google integration.
- Automated Reconnection: Using Homey’s flow editor, I created a flow that detects when the connection drops and automatically triggers a reconnection attempt.
- Notifications: Added a notification to alert me if the issue persists, so I know when manual intervention is needed.
The Result
This setup has significantly reduced the downtime I was experiencing. While it doesn’t eliminate the problem entirely, it has made managing the integration much more straightforward. I no longer have to manually restart everything every time there’s an issue, which is a huge relief!
Tips for Others
If you’re facing similar issues, here are a few tips:
- Check for Updates: Ensure both Homey and Google Assistant apps are up to date.
- Logs are Your Friend: Regularly review the logs for any error messages that could provide clues.
- Community Support: Don’t hesitate to reach out to the community. Someone might have already found a workaround!
It’s been a bit of a rollercoaster, but problem-solving like this is part of the fun of setting up a smart home. I’m glad I could figure this out and hope it helps others too!
Happy automating! ![]()
