I recently encountered an interesting challenge with my HDPM 6000 units, and I wanted to share my experience in case it helps anyone else. After setting up one for testing, I noticed that the current readings were almost double what my manual clamp meter was showing. At first, I was a bit puzzled and concerned, but after some troubleshooting, I figured out the cause and got everything working smoothly.**The Issue:**When I compared the HDPM 6000’s readings with my manual clamp meter, the numbers didn’t match up. The HDPM was showing significantly higher values. I checked the setup again to ensure everything was configured correctly, but everything seemed fine. The Modbus communication was working, and I could read the registers without any issues.**The Solution:**After some research and reaching out to the support team, I discovered that the issue was related to the device’s configuration settings. It turned out that the scaling factor for the current readings hadn’t been adjusted correctly during setup. Once I updated the scaling factor to match the actual current transformers (CTs) being used, the readings aligned perfectly with my manual measurements.**Steps I Took:**1. Checked Configuration: I reviewed the device’s configuration to ensure the CT ratios and scaling factors were set correctly.2. Consulted Documentation: I referred to the HDPM 6000’s manual and online resources to understand how the scaling settings affect the readings.3. Adjusted Settings: I adjusted the scaling factor to match the CTs installed in my panel.4. Verified Readings: After making the changes, I cross-referenced the HDPM’s readings with my clamp meter to confirm accuracy.**Outcome:**It was a relief to see the readings stabilize and match my manual measurements. This experience taught me the importance of double-checking configuration settings, especially when dealing with precise measurements. I’m now confident that my system is providing accurate data, which is crucial for monitoring and analysis.If anyone else is experiencing similar issues, I encourage you to review your device’s configuration and consult the manufacturer’s guidelines. A small adjustment can often make a big difference!
