Hey everyone, I wanted to share my recent experience with integrating a Schlage lock with Vera. It’s been a bit of a learning curve, but I managed to figure it out, and I hope this helps others facing similar issues.
So, the problem I was having was that while I could delete codes and lock/unlock the door remotely, I couldn’t add new codes through Vera. The code would show as entered successfully but wouldn’t work on the lock. After some research and trial and error, I discovered that the issue was with the Vera’s firmware. Updating it to the latest version resolved the problem!
Here’s what I did:
- Checked Vera’s settings for available updates.
- Updated the firmware following the instructions in the user manual.
- After the update, I retried adding a code through Vera, and it worked perfectly!
This was a bit frustrating at first, but it taught me the importance of keeping firmware up to date. If anyone else is having similar issues, I highly recommend checking for firmware updates before diving into more complex troubleshooting.
If you have any other tips or experiences to share, I’d love to hear them! Let’s keep learning and improving our smart home setups together. ![]()
