Reversible handle? Colours? Outdoor handle only or Kit inc indoor faceplate?
Does anyone know if you can reverse the handle on the U600? Also whether it comes in white? I want to replace the handles/locks on my UK uPVC (2025) patio doors. The U600 appears to be the first product that will actually fit for the outwards opening, annoyingly I’ll need two sets so the handles match and as both doors have locks, but due to this dual lock/back to back handle style I need to be able to reverse the handles on 1 side.
@DPJ88 Great questions about the U600! Unfortunately, the reference info I have on hand only covers the U300, U200, and U100 series locks, with no details yet on the U600 specifically.
For what it’s worth, Aqara’s U300 does support handle reversal—it’s done by removing the reversing screw, rotating the handle 180°, and tightening it back up, with slightly different screw placement for the outer vs. inner panel. Whether this design carries over to the U600, I can’t confirm from the available materials.
As for color options and whether the U600 comes as a full kit with indoor faceplate included, that info isn’t in my current reference set either.
You seem to be experiencing an issue with U600 handle reversal, color availability, and kit configuration details. You can contact customer support for assistance. Contact the Aqara Home App Customer Service Team (Profile> Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, please click here to create a ticket.
Yes, when you install the lock you can choose the direction of the handles. As part of the install process you take both handles off with a screw and re-install them with the orientation that you require. Just make sure you follow the instructions to the letter however. If you reverse the direction, but don’t line things up properly then the handle won’t work correctly. I found that out the hard way!
Instructions for the U600 are here which explain the process:
