I recently encountered an issue with my RFXCOM device after reinstalling my openHAB machine. Despite configuring everything correctly, the device wasn’t connecting. Here’s my journey to resolving the problem and what I learned along the way.After reinstalling openHAB on my Raspberry Pi, I noticed that my RFXCOM device wasn’t being recognized. I checked the serial port settings, permissions, and even reinstalled the necessary drivers, but nothing seemed to work. The logs indicated a ‘NoSuchPortException’, suggesting a permission issue or incorrect port configuration.I started by verifying the device permissions. I added the openHAB user to the ‘dialout’ group and adjusted the ownership of the symlink. However, the problem persisted. I then reviewed the openHAB configuration files, ensuring that the serial port was correctly specified and that all necessary Java arguments were in place.To troubleshoot further, I tested the RFXCOM device using the rfxcmd utility, which confirmed that the device was functioning correctly. This ruled out hardware issues and pointed towards a configuration problem within openHAB.After some research, I discovered that the issue might be related to the Java library path. I adjusted the JAVA_ARGS in the init.d script to include the correct library path and retried the connection. This time, the device connected successfully!This experience taught me the importance of meticulous configuration checks and the value of community resources in troubleshooting. If anyone else is facing similar issues, I recommend verifying device permissions, checking the Java arguments, and testing the device outside of openHAB to isolate the problem.Thank you to the community for your support and resources! Here’s to smoother connections in the future. ![]()
