I’ve been diving into the world of smart home automation, and I must say, it’s been an exciting journey! One of my latest projects has been setting up RGB lighting automation in my backyard. I wanted to create a vibrant, dynamic ambiance for parties and gatherings, so I decided to use RGB Zigbee spots controlled by a Conbee2 gateway.
Initially, my goal was simple: have the lights change colors randomly every two seconds. I set up an automation script with a scene creation and a repeating loop to trigger the color changes. I thought it would be straightforward, but as it turns out, the lights were changing colors much faster than expected, and the interval wasn’t consistent. Sometimes it was every 5 seconds, other times 3 or even 6. Definitely not the two-second interval I had envisioned!
I spent hours tweaking the script, adjusting delays, and checking the logic. One thing I realized was the importance of ensuring that the random color generation and brightness adjustments were properly synchronized. I also had to make sure that the transition time between colors was smooth enough to avoid any flickering.
After several iterations and some trial and error, I finally got it right! The lights now change colors every two seconds, creating a mesmerizing effect that’s perfect for any party. It’s moments like these that make me appreciate the flexibility and creativity that smart home automation offers.
If anyone has tips or tricks for optimizing RGB lighting automations, I’d love to hear them! Let’s keep the learning and sharing going. ![]()
