I’ve recently installed RGBW LED strips in my living room, and it’s been a fantastic addition to my smart home setup. The ability to change colors and brightness has really transformed the ambiance of the space. However, I did run into a few challenges along the way that I’d like to share in case others are facing similar issues.
Initially, I wanted to control the LED strips using both physical switches and voice commands. After some research, I decided to use a Sonoff T1UK switch, which I flashed with Tasmota firmware. The setup process was a bit tricky at first, especially since there’s no reset switch, but once I got the hang of it, everything fell into place. I integrated the switch with OpenHAB and Google Home, which worked seamlessly.
The main challenge I faced was controlling the color settings. I considered wiring a WiFi RGBW controller between the switch and the strip, but I was concerned about potential delays and the loss of control from OpenHAB. After some experimentation, I found that using a separate ESP32 controller for color management was the most elegant solution. This setup allowed me to maintain full control over the color settings while keeping the physical switch for on/off functionality.
One feature I particularly love is the ability to set color rules based on the time of day. For example, during the evening, the lights automatically shift to a warmer tone to create a cozy atmosphere. This was achieved by setting up a simple rule in OpenHAB that adjusts the color temperature based on the current time.
I also encountered an issue with the LED strips flickering at low brightness levels. After some research, I discovered that this was due to the type of dimmer I was using. Switching to a trailing-edge dimmer resolved the problem completely, and now the lights operate smoothly across the entire brightness spectrum.
Overall, my experience with RGBW LED strips has been very positive. They’ve added a whole new dimension to my smart home, and with a little troubleshooting, I was able to overcome any initial hurdles. If you’re considering installing RGBW LED strips, I highly recommend taking the time to plan your control setup carefully and don’t hesitate to experiment with different configurations to find what works best for you.
