Hi everyone, I’ve been using my robot vacuum for a while now, and I’ve noticed an interesting behavior regarding its charging. When the charging level drops below 10%, it heads back to the base station, which is as expected. However, it only charges up to about 60% before resuming its cleaning job. This often means it doesn’t have enough power to finish the task and ends up needing to recharge again. I’m curious if there’s a way to adjust the charging percentage so that it fully charges to 100% before continuing. I think this would make the cleaning process more efficient and reduce the number of times it needs to recharge throughout the house. If anyone has any tips or insights on how to set this up, I’d really appreciate the help! Thanks in advance for your advice.
